buzz Wrote:
> reprap has a strong history with polymorph. it
> was one of the first plastic/s that was considered
> ( after hot-glue , I think). There were serious
:-D I must admit I thought of hot-glue also ;-)
> problems with polymorph, which I think included
> it's shrinkage properties, and possibly the fact
> that it broke-down under temperature. I've not
> personally tried extruding it.
Using polymorph as repstrat-mendel could be usefull.. all you need to do is
1) make some mould for example from modelling clay or something
2) mold your essential mendel-parts. 60 C is not too hot.. just boil some water
3) print the parts with ABS or something
I have an impression that using repstrapper, you would end up getting a lot of material you cannot use on the actual mendel. After making the finished parts, you can re-use the polymorph.
