Anyone made parts from 'polymorph'
Posted by nite69
February 06, 2010 07:07PM
Polymorph is a plastic that melts in 60 degrees. maybe it could be used to get some kind of booststrap - mendel?
[en.wikipedia.org]
[letsmakerobots.com]
Maybe this could also be used as support material?
Edited 2 time(s). Last edit at 02/06/2010 07:10PM by nite69.
Re: Anyone made parts from 'polymorph'
February 07, 2010 09:12PM
reprap has a strong history with polymorph. it was one of the first plastic/s that was considered ( after hot-glue , I think). There were serious problems with polymorph, which I think included it's shrinkage properties, and possibly the fact that it broke-down under temperature. I've not personally tried extruding it.
February 11, 2010 01:52PM
:-D I must admit I thought of hot-glue also ;-)
Using polymorph as repstrat-mendel could be usefull.. all you need to do is
1) make some mould for example from modelling clay or something
2) mold your essential mendel-parts. 60 C is not too hot.. just boil some water
3) print the parts with ABS or something
I have an impression that using repstrapper, you would end up getting a lot of material you cannot use on the actual mendel. After making the finished parts, you can re-use the polymorph.
