Motor Problem June 16, 2014 11:45AM |
Re: Motor Problem June 16, 2014 12:29PM |
Re: Motor Problem June 17, 2014 08:26AM |
Disconnect all motors and stepper drivers. Then, install a single stepper driver into the X-Axis and hook up a single stepper motor. It doesn't matter which one. Power up and connect to the Arduino. Send a command to move a single motor 1mm. Did it move? If so, repeat for other motors and stepper drivers, one at a time. Unplug power and usb before any changes. If this did NOT work, try another stepper driver. If this does not work, you may have an issue with your RAMPS or Arduino.|
Re: Motor Problem June 17, 2014 06:06PM |
Re: Motor Problem June 18, 2014 05:17AM |
