Hello,
I'm reading the docs but I'm a bit confused over two simple things:
- "Mendel-m4-assembly-data-sheet" says two different things about cap screws: first ("BOM"), that I will need 4 x "m3-capx25" and 1 x "m4-capx20" but later ("Fasteners...") it does not mentions them and includes them in "m3-capx20" and "m4x16-cap".
Will I need those 4 + 1 special screws or is it possible to get away without them?
- Mendel needs 3 belts but the data-sheet lists only two (I should split BX). But how to get the right length? I should just cut BX and BY in the middle? And how long should BZ be? And should I split BZ in the same way as I'm going to split BX ("Belt splitter jig")?
(* There is "BELT SPECIFICATIONS (READ NOTES TA
" but I don't see it, probably the data-sheet got somewhat corrupted as I converted it)
Thanks!
