Prusa i3 build with RAMPS1.4 and Pronterface - Motors are not turning July 26, 2014 08:45PM |
Re: Prusa i3 build with RAMPS1.4 and Pronterface - Motors are not turning July 27, 2014 10:03AM |
This sounds like Marlin's insane default feedrate/acceleration/jerk. The speed it's asking the motors to run at is simply something the stepper drivers can't do.
Here's my feedrates, they are a little slow though:
#define HOMING_FEEDRATE {3000, 3000, 100, 0}
#define DEFAULT_AXIS_STEPS_PER_UNIT {80,80,4100,650}
#define DEFAULT_MAX_FEEDRATE {120, 120, 2.5, 50}
#define DEFAULT_MAX_ACCELERATION {120,120,5,800}
#define DEFAULT_ACCELERATION 50
#define DEFAULT_RETRACT_ACCELERATION 50
#define DEFAULT_XYJERK 20 // (mm/sec)
#define DEFAULT_ZJERK 1 // (mm/sec)
#define DEFAULT_EJERK 20 // (mm/sec)
Once you're sure that the feedrates are reasonable, if this issue still occurs you will need to adjust the trimpots on the stepper motor drivers.
Re: Prusa i3 build with RAMPS1.4 and Pronterface - Motors are not turning July 27, 2014 10:23AM |
Re: Prusa i3 build with RAMPS1.4 and Pronterface - Motors are not turning July 27, 2014 11:15PM |
Re: Prusa i3 build with RAMPS1.4 and Pronterface - Motors are not turning July 29, 2014 03:05AM |
Re: Prusa i3 build with RAMPS1.4 and Pronterface - Motors are not turning October 27, 2014 05:24AM |
Re: Prusa i3 build with RAMPS1.4 and Pronterface - Motors are not turning October 27, 2014 05:30AM |
Re: Prusa i3 build with RAMPS1.4 and Pronterface - Motors are not turning October 27, 2014 06:36AM |
Re: Prusa i3 build with RAMPS1.4 and Pronterface - Motors are not turning October 27, 2014 08:01AM |
