trying to figure out what is wrong with my first test print
Posted by lgleasain
August 21, 2014 01:11PM
I'm having problems getting my first prints right. I'm using ABS with a headbed set to 110 and a extruder set to 230.
Below are the prints. My printer is a Prusa i3
I'm using Cura and Pronterface and my settings are attached with cura and my extruder is set at 90mm @ 90mm/min
open | download - print2.jpg (77.3 KB)
open | download - print1.jpg (73.2 KB)
open | download - settings1.jpg (114.4 KB)
Re: trying to figure out what is wrong with my first test print
August 21, 2014 03:30PM
Is it supposed to be rotating? Hard to tell what exactly is wrong with it; dark, unclear images. Can you explain more?
Realizer- One who realizes dreams by making them a reality either by possibility or by completion. Also creating or renewing hopes of dreams.
"keep in mind, even the best printer can not print with the best filament if the user is the problem." -Ohmarinus
August 22, 2014 02:35AM
Have you calibrated your X and Y axes'?
_______________________________________
Waitaki 3D Printer
August 22, 2014 08:19PM
Posted some photos that are hopefully better.
Both of these are the 20mm-box.stl on the [reprap.org] page. They are supposed to be symetrical squares.
open | download - non_even.jpg (56.7 KB)
open | download - non_even2.jpg (152.8 KB)
August 23, 2014 05:50PM
Might be loose belts. Might be a loose bed - is your bed on springs? Does it move in the horizontal plane at all?
[3DKarma.com] - suppliers of quality, affordable 3D printer kits and filament for the UK market.
