Mendel Extruder Head Ribbon Cable
Posted by rusdp
April 05, 2010 12:05AM
Hey guys. This should be the last of thing I need to get. I am currently looking for the "200mm 4-way ribbon cable" for the Mendel Extruder head. Any places you know where I can get it in the US?
Also, will Kapton tape work for the heatshrink needed?
Thanks for all your help.
- rusdp
Re: Mendel Extruder Head Ribbon Cable
April 06, 2010 01:37AM
Any ideas then about this?
April 06, 2010 02:04AM
What would be useful to know at least is the gauge size of the ribbon cable.
Thanks.
-rusdp
April 06, 2010 01:23PM
Hey, ribbon cable is pretty standard - it's 0.05" between the cables. If you find any dead PC's around, you could snag some off the hard drive cables, or just order some up from Digikey.
That said, pretty much any small wire will work for the extruder - no need to use ribbon cable.
April 11, 2010 11:25PM
buy some 9 or 10 conductor ribbon cable from All Electronics and cut off the conductors you don't need?
-J
-J
True wisdom lies in knowing that you know nothing
