Re: LaserCut Mendel by Tech Zone Remix ![]() June 08, 2010 03:27PM |
Re: LaserCut Mendel by Tech Zone Remix ![]() June 10, 2010 01:52AM |
Re: LaserCut Mendel by Tech Zone Remix ![]() June 11, 2010 01:40AM |
Re: LaserCut Mendel by Tech Zone Remix ![]() June 11, 2010 03:20AM |
Admin Registered: 13 years ago Posts: 476 |
ziplock
A word to the wise: If you buy a Mendel hardware kit from Ultimachine, invest in a good ruler or micrometer that reads up to 300mm. Jigging is a pain if you don't have a good measurement device.
Re: LaserCut Mendel by Tech Zone Remix ![]() June 11, 2010 10:46AM |
Re: LaserCut Mendel by Tech Zone Remix ![]() June 13, 2010 06:56PM |
Re: LaserCut Mendel by Tech Zone Remix ![]() June 13, 2010 10:04PM |
Re: LaserCut Mendel by Tech Zone Remix ![]() June 15, 2010 08:23AM |
Re: LaserCut Mendel by Tech Zone Remix ![]() June 15, 2010 09:33AM |
Re: LaserCut Mendel by Tech Zone Remix ![]() June 15, 2010 11:12AM |
Admin Registered: 13 years ago Posts: 7,853 |
Note: File had to be attached because the Phorum software sucks. If does not honor standard forum commands, neither quote or code work corerctly. Boo, hiss
class Thermistor: "Class to do the thermistor maths" def __init__(self, r0, t0, beta, r1, r2): self.r0 = r0 # stated resistance, e.g. 10K self.t0 = t0 + 273.15 # temperature at stated resistance, e.g. 25C self.beta = beta # stated beta, e.g. 3500 self.vadc = 5.0 # ADC reference self.vcc = 5.0 # supply voltage to potential divider self.vs = r1 * self.vcc / (r1 + r2) # effective bias voltage self.rs = r1 * r2 / (r1 + r2) # effective bias impedance self.k = r0 * exp(-beta / self.t0) # constant part of calculation def temp(self,adc): "Convert ADC reading into a temperature in Celcius" v = adc * self.vadc / 1024 # convert the 10 bit ADC value to a voltage r = self.rs * v / (self.vs - v) # resistance of thermistor return (self.beta / log(r / self.k)) - 273.15 # temperature def setting(self, t): "Convert a temperature into a ADC value" r = self.r0 * exp(self.beta * (1 / (t + 273.15) - 1 / self.t0)) # resistance of the thermistor v = self.vs * r / (self.rs + r) # the voltage at the potential divider return round(v / self.vadc * 1024) # the ADC reading
Re: LaserCut Mendel by Tech Zone Remix ![]() June 15, 2010 12:11PM |
Re: LaserCut Mendel by Tech Zone Remix ![]() June 15, 2010 12:46PM |
Re: LaserCut Mendel by Tech Zone Remix ![]() June 16, 2010 10:13AM |
Re: LaserCut Mendel by Tech Zone Remix ![]() June 23, 2010 03:07AM |
Re: LaserCut Mendel by Tech Zone Remix ![]() June 23, 2010 04:42AM |
Re: LaserCut Mendel by Tech Zone Remix ![]() June 23, 2010 07:56AM |
Re: LaserCut Mendel by Tech Zone Remix ![]() June 23, 2010 08:21AM |
Lambert Andrus
I also knew that the build plate needs to have a little filing done, but I wanted to make sure that the plate itself gets attached under the screws too, I have found that a sharp knife does a fine job of cutting a little notch in the aluminum (although the knife is usually not sharp when done).
Re: LaserCut Mendel by Tech Zone Remix ![]() June 23, 2010 08:56AM |
Re: LaserCut Mendel by Tech Zone Remix ![]() June 23, 2010 09:03AM |
Re: LaserCut Mendel by Tech Zone Remix ![]() June 28, 2010 12:39PM |
Re: LaserCut Mendel by Tech Zone Remix ![]() June 28, 2010 11:05PM |
Re: LaserCut Mendel by Tech Zone Remix ![]() June 29, 2010 04:37AM |
Re: LaserCut Mendel by Tech Zone Remix ![]() June 29, 2010 05:00PM |
Re: LaserCut Mendel by Tech Zone Remix ![]() July 12, 2010 09:21AM |
Re: LaserCut Mendel by Tech Zone Remix ![]() July 12, 2010 11:36AM |
Re: LaserCut Mendel by Tech Zone Remix ![]() July 13, 2010 04:07AM |
Re: LaserCut Mendel by Tech Zone Remix ![]() July 13, 2010 08:00AM |
Re: LaserCut Mendel by Tech Zone Remix ![]() July 31, 2010 12:13AM |
Re: LaserCut Mendel by Tech Zone Remix ![]() July 31, 2010 01:33AM |
Re: LaserCut Mendel by Tech Zone Remix ![]() July 31, 2010 04:39PM |
