Re: LaserCut Mendel by Tech Zone Remix June 08, 2010 03:27PM |
Re: LaserCut Mendel by Tech Zone Remix June 10, 2010 01:52AM |
Re: LaserCut Mendel by Tech Zone Remix June 11, 2010 01:40AM |
Re: LaserCut Mendel by Tech Zone Remix June 11, 2010 03:20AM |
Admin Registered: 19 years ago Posts: 476 |
ziplock
A word to the wise: If you buy a Mendel hardware kit from Ultimachine, invest in a good ruler or micrometer that reads up to 300mm. Jigging is a pain if you don't have a good measurement device.
Re: LaserCut Mendel by Tech Zone Remix June 11, 2010 10:46AM |
Re: LaserCut Mendel by Tech Zone Remix June 13, 2010 06:56PM |
Re: LaserCut Mendel by Tech Zone Remix June 13, 2010 10:04PM |
Re: LaserCut Mendel by Tech Zone Remix June 15, 2010 08:23AM |
Re: LaserCut Mendel by Tech Zone Remix June 15, 2010 09:33AM |
Folding@home is my all consuming activity. I'm about #1,381 out of 1.4 million contributors. ref: [folding.extremeoverclocking.com]
Re: LaserCut Mendel by Tech Zone Remix June 15, 2010 11:12AM |
Admin Registered: 19 years ago Posts: 7,883 |
Note: File had to be attached because the Phorum software sucks. If does not honor standard forum commands, neither quote or code work corerctly. Boo, hiss
class Thermistor:
"Class to do the thermistor maths"
def __init__(self, r0, t0, beta, r1, r2):
self.r0 = r0 # stated resistance, e.g. 10K
self.t0 = t0 + 273.15 # temperature at stated resistance, e.g. 25C
self.beta = beta # stated beta, e.g. 3500
self.vadc = 5.0 # ADC reference
self.vcc = 5.0 # supply voltage to potential divider
self.vs = r1 * self.vcc / (r1 + r2) # effective bias voltage
self.rs = r1 * r2 / (r1 + r2) # effective bias impedance
self.k = r0 * exp(-beta / self.t0) # constant part of calculation
def temp(self,adc):
"Convert ADC reading into a temperature in Celcius"
v = adc * self.vadc / 1024 # convert the 10 bit ADC value to a voltage
r = self.rs * v / (self.vs - v) # resistance of thermistor
return (self.beta / log(r / self.k)) - 273.15 # temperature
def setting(self, t):
"Convert a temperature into a ADC value"
r = self.r0 * exp(self.beta * (1 / (t + 273.15) - 1 / self.t0)) # resistance of the thermistor
v = self.vs * r / (self.rs + r) # the voltage at the potential divider
return round(v / self.vadc * 1024) # the ADC reading
Re: LaserCut Mendel by Tech Zone Remix June 15, 2010 12:11PM |
Re: LaserCut Mendel by Tech Zone Remix June 15, 2010 12:46PM |
Re: LaserCut Mendel by Tech Zone Remix June 16, 2010 10:13AM |
Re: LaserCut Mendel by Tech Zone Remix June 23, 2010 03:07AM |
Re: LaserCut Mendel by Tech Zone Remix June 23, 2010 04:42AM |
Re: LaserCut Mendel by Tech Zone Remix June 23, 2010 07:56AM |
Re: LaserCut Mendel by Tech Zone Remix June 23, 2010 08:21AM |
Lambert Andrus
I also knew that the build plate needs to have a little filing done, but I wanted to make sure that the plate itself gets attached under the screws too, I have found that a sharp knife does a fine job of cutting a little notch in the aluminum (although the knife is usually not sharp when done).
Re: LaserCut Mendel by Tech Zone Remix June 23, 2010 08:56AM |
Re: LaserCut Mendel by Tech Zone Remix June 23, 2010 09:03AM |
Re: LaserCut Mendel by Tech Zone Remix June 28, 2010 12:39PM |
Re: LaserCut Mendel by Tech Zone Remix June 28, 2010 11:05PM |
Re: LaserCut Mendel by Tech Zone Remix June 29, 2010 04:37AM |
Re: LaserCut Mendel by Tech Zone Remix June 29, 2010 05:00PM |
Re: LaserCut Mendel by Tech Zone Remix July 12, 2010 09:21AM |
Re: LaserCut Mendel by Tech Zone Remix July 12, 2010 11:36AM |
Re: LaserCut Mendel by Tech Zone Remix July 13, 2010 04:07AM |
Re: LaserCut Mendel by Tech Zone Remix July 13, 2010 08:00AM |
Plan to use baking foil or 0.001 brass shim stock on wide tape and ground them and see how that works. There's some junk stainless braided hose around from car parts that would look cool but is too hard to work.
Re: LaserCut Mendel by Tech Zone Remix July 31, 2010 12:13AM |
Re: LaserCut Mendel by Tech Zone Remix July 31, 2010 01:33AM |
Re: LaserCut Mendel by Tech Zone Remix July 31, 2010 04:39PM |
