Extruder problem December 13, 2014 04:44PM |
Re: Extruder problem December 13, 2014 04:46PM |
Re: Extruder problem December 14, 2014 05:52AM |
Re: Extruder problem December 16, 2014 12:47AM |
Re: Extruder problem December 16, 2014 01:09AM |
LNButts
I had a similar issue a few weeks ago. I had rapidly pulled some filament out by hand, and I guess some semi-liquid filament stuck to the walls of the head-sink and was blocking the filament. I popped the blockage out with a drill bit and that was it.
Try measuring a length of filament and sticking it down towards the nozzle. See how far it gets (so you know where you have the blockage). If its near the nozzle, heat 'er up and try to push it through. If its above the nozzle, you've got an upstream blockage that you will need to remove by hand.
Re: Extruder problem December 16, 2014 11:38PM |
Re: Extruder problem January 13, 2015 11:33AM |
