Possible to use sgraber's lasercut frame with Rework parts? December 17, 2014 07:23AM |
Re: Possible to use sgraber's lasercut frame with Rework parts? December 17, 2014 10:23PM |
Re: Possible to use sgraber's lasercut frame with Rework parts? December 18, 2014 07:46AM |
Re: Possible to use sgraber's lasercut frame with Rework parts? December 18, 2014 08:30PM |
carl67lp
Thanks, vegasloki -- this is exactly the information I needed. Indeed, I actually had your frame on my eBay watch list.
That said, I don't see a rod kit in your eBay store that has the longer upper rear cross rod; all of them seem to have four cross rods of equal length. Am I missing something?
Re: Possible to use sgraber's lasercut frame with Rework parts? December 11, 2015 09:41AM |
Re: Possible to use sgraber's lasercut frame with Rework parts? December 11, 2015 10:51AM |
vegasloki
The difference in the frames are the rear slots on the uprights. On a Rework there are M10 rods and that changed the centerline of the cross rods so the slot is a bit higher and cut a bit wider. Either frame could be made to work by cutting the slots in the uprights where the rods mount.
Re: Possible to use sgraber's lasercut frame with Rework parts? December 12, 2015 04:16AM |
