Mendel
Posted by rcarrier31
Mendel
December 29, 2014 06:32PM
Hello, i am new to these forums, i have got an issue with my mendel printer,
Everything i print is double the size on the z axis, i am certain it is a firmware
issue, but i cannot find it, i am running marlin firmware with cura.
Any help would be appreciated
Edited 1 time(s). Last edit at 12/29/2014 06:32PM by rcarrier31.
Re: Mendel
December 29, 2014 09:56PM
rcarrier31
What controller? RAMPS? are there 3 jumpers under the driver?
For your firmware use the Prusa calculator for your Z steps
[prusaprinters.org]
Steve
My updated Instructable on our Prusa i3 Build
[www.instructables.com]
Re: Mendel
December 30, 2014 03:17AM
Makerbase v 1.0 controller, no ramps, z is direct drive, table moves.
Re: Mendel
December 30, 2014 08:04AM
Either your jumper on your stepper driver is wrong or the E_STEPS_PER_MM_Z is wrong on your firmware.
Bob Morrison
Wörth am Rhein, Germany
"Luke, use the source!"
BLOG - PHOTOS - Thingiverse
Re: Mendel
December 30, 2014 12:25PM
I dont see any jumpers on the board, and cannot find that command in the firmware?
which library should it be in?
Re: Mendel
December 31, 2014 10:58AM
Hello
It is the firmware. You can set as follows:
Most RepRap printers use a pair of threaded rods for the Z axis. So to calculate how far the Z axis moves for each revolution of the motor, first you need to know how much rotation is being transmitted to the Z rods, and then use the "thread pitch" of the rod (distance-per-revolution) to determine the vertical motion.
The basic formula to calculate motion on a rotating rod is:
steps_per_mm = (motor_steps_per_rev * driver_microstep) / thread_pitch
Some common examples:
// NEMA 17 with standard pitch M5 threaded rod:
(200 * 16) / 0.8 = 4000
// NEMA 17 with standard pitch M8 threaded rod:
(200 * 16) / 1.25 = 2560
// NEMA 17 with SAE 5/16" threaded rod. It has 18 threads per inch (25.4mm / 18):
(200 * 16) / (25.4 / 18) = 2267.7165355
see more at [reprap.org]
Everything of 3D printer. www.3dminions.com
[www.facebook.com]
