Prusa i3v homing issue January 11, 2015 09:31PM |
Re: Prusa i3v homing issue January 12, 2015 01:05PM |
Re: Prusa i3v homing issue January 12, 2015 09:11PM |
Plasteroid
You did not provide enough info: firmware, endstops type etc. min or max? Perhaps the endstop plugs are lose or wires broken? If it worked before, I think that it can be something like broken wires (Once happened to me). Do you use Pronterface or... send commands M119 or M114 ?
Re: Prusa i3v homing issue January 13, 2015 06:56AM |
Re: Prusa i3v homing issue January 13, 2015 09:48PM |
Plasteroid
If it sometimes works and sometimes not it sounds like a connector / wire loose problem? 3D printers usually shake a lot... How the software could change without doing nothing? Or your electronics board has something loose?. I have same type connectors with three wires, but no LCD.
P.S. Did you check this? "Homing issues with Marlin" there are few solutions: [forums.reprap.org]
Re: Prusa i3v homing issue January 15, 2015 06:06AM |
