Y axis inverted ?
March 29, 2015 05:02PM
Just print my first part this morning and my Y axis is inverted ;
if you look on picture 1 x=190 y=0 z=0 where y should be 190
if you look on picture 2 x=190 y=190 z=0 where y should be 0
i'm using Marlin and here is my config h mechanical settings
//=============================Mechanical Settings===========================
// Uncomment the following line to enable CoreXY kinematics
// #define COREXY
// coarse Endstop Settings
#define ENDSTOPPULLUPS // Comment this out (using // at the start of the line) to disable the endstop pullup resistors
#ifndef ENDSTOPPULLUPS
// fine endstop settings: Individual pullups. will be ignored if ENDSTOPPULLUPS is defined
// #define ENDSTOPPULLUP_XMAX
// #define ENDSTOPPULLUP_YMAX
// #define ENDSTOPPULLUP_ZMAX
// #define ENDSTOPPULLUP_XMIN
// #define ENDSTOPPULLUP_YMIN
// #define ENDSTOPPULLUP_ZMIN
#endif
#ifdef ENDSTOPPULLUPS
#endif
// The pullups are needed if you directly connect a mechanical endswitch between the signal and ground pins.
const bool X_MIN_ENDSTOP_INVERTING = true; // set to true to invert the logic of the endstop.
const bool Y_MIN_ENDSTOP_INVERTING = true; // set to true to invert the logic of the endstop.
const bool Z_MIN_ENDSTOP_INVERTING = true; // set to true to invert the logic of the endstop.
const bool X_MAX_ENDSTOP_INVERTING = true; // set to true to invert the logic of the endstop.
const bool Y_MAX_ENDSTOP_INVERTING = true; // set to true to invert the logic of the endstop.
const bool Z_MAX_ENDSTOP_INVERTING = true; // set to true to invert the logic of the endstop.
//#define DISABLE_MAX_ENDSTOPS
//#define DISABLE_MIN_ENDSTOPS
// Disable max endstops for compatibility with endstop checking routine
#if defined(COREXY) && !defined(DISABLE_MAX_ENDSTOPS)
#endif
#define X_ENABLE_ON 0
#define Y_ENABLE_ON 0
#define Z_ENABLE_ON 0
#define E_ENABLE_ON 0 // For all extruders
// Disables axis when it's not being used.
#define DISABLE_X false
#define DISABLE_Y false
#define DISABLE_Z false
#define DISABLE_E false // For all extruders
#define DISABLE_INACTIVE_EXTRUDER true //disable only inactive extruders and keep active extruder enabled
#define INVERT_X_DIR false // for Mendel set to false, for Orca set to true
#define INVERT_Y_DIR true // for Mendel set to true, for Orca set to false
#define INVERT_Z_DIR false // for Mendel set to false, for Orca set to true
#define INVERT_E0_DIR true // for direct drive extruder v9 set to true, for geared extruder set to false
#define INVERT_E1_DIR false // for direct drive extruder v9 set to true, for geared extruder set to false
#define INVERT_E2_DIR false // for direct drive extruder v9 set to true, for geared extruder set to false
// ENDSTOP SETTINGS:
#define X_HOME_DIR 1
#define Y_HOME_DIR -1
#define Z_HOME_DIR -1
#define min_software_endstops true // If true, axis won't move to coordinates less than HOME_POS.
#define max_software_endstops true // If true, axis won't move to coordinates greater than the defined lengths below.
// Travel limits after homing
#define X_MAX_POS 190
#define X_MIN_POS 0
#define Y_MAX_POS 190
#define Y_MIN_POS 0
#define Z_MAX_POS 190
#define Z_MIN_POS 0
#define X_MAX_LENGTH (X_MAX_POS - X_MIN_POS)
#define Y_MAX_LENGTH (Y_MAX_POS - Y_MIN_POS)
#define Z_MAX_LENGTH (Z_MAX_POS - Z_MIN_POS)
is somebody can help me please ?
open | download - picture1.jpg (184.4 KB)
open | download - picture2.jpg (172.5 KB)
Re: Y axis inverted ?
March 29, 2015 06:06PM
From your pic, shouldnt the y-axis end stop switch be at the back of your printer not the front?
If so move it to the back then invert your y-axis. Either through the motor wiring or the firmware.
Gordon
March 30, 2015 05:41PM
Gordon is correct. The correct position for your Y-endstop is at the back.
X-endstop at the left.
Z-endstop on the bottom.
Good luck! smiling smiley
http://www.marinusdebeer.nl/
March 30, 2015 07:16PM
Ohmarinus
Look at the attach picture from wiki Prusa I3 rework, x-endstop on the right, y-endstop on the front. I'm gonna try again tonight or tomorrow and let you know
open | download - PRUSA_i3_Front.jpg (160.3 KB)
March 30, 2015 07:47PM
charliebe
Ohmarinus
If you have the Y endstop at the front then it's a MAX endstop, your firmware is set for a MIN endstop
Steve
My updated Instructable on our Prusa i3 Build
[www.instructables.com]
March 30, 2015 08:01PM
I got it ! I invert the y motor, change homing direction and connect the y endstop to the other connection on the ramp 1.4. I think there is 2 connections per axis on the ramp.
I'm gonna try a print now
March 31, 2015 05:13AM
On the ramps board there are connections for xyz min and max endstops.
But you still need to set it in firmware.
Gordon
