Need to decide 5mm, 8mm or proper leadscrews April 25, 2015 01:47PM |
Re: Need to decide 5mm, 8mm or proper leadscrews April 25, 2015 05:07PM |
Re: Need to decide 5mm, 8mm or proper leadscrews April 25, 2015 05:13PM |
Re: Need to decide 5mm, 8mm or proper leadscrews April 25, 2015 05:58PM |
Re: Need to decide 5mm, 8mm or proper leadscrews April 25, 2015 06:15PM |
Re: Need to decide 5mm, 8mm or proper leadscrews April 25, 2015 07:02PM |
Re: Need to decide 5mm, 8mm or proper leadscrews April 25, 2015 07:57PM |
gordonendersby
I thought the reason the i3 going for m5x1mm is the thread pitch and steps to pitch ratio.
Before that it was 8mmx1.25 threaded rod as per the i2 frame.
The zink coated threaded rods are formed with the thread undersized ready for the zinc coating.
The stainless are cut threads, smoother and more accurate.
M5 come as 1mm thread pitch.
M8 come as 1.25mm thread pitch.
The 8mm lead screw comes as fine 1.50mm pitch.
The 8mm lead screws standard is 2mm pitch.
So im trying to compare the pitches against the accuracy as much as anything.
Definetly want to ignore the zinc coated. Why have the rough zinc coating when stainless smooth cut threads are not much more.
So is it worth going on to the proper lead screws even though the pitch is lower.
Stick with m8 that i know Ive got good results from. Not a problem to import the files and change the x-ends to 13m hex heads.
Or will the 5mm x 1mm thread and pitch get me near to the proper lead screws anyway.
Gordon
Re: Need to decide 5mm, 8mm or proper leadscrews April 25, 2015 08:28PM |
Re: Need to decide 5mm, 8mm or proper leadscrews April 25, 2015 09:47PM |
Re: Need to decide 5mm, 8mm or proper leadscrews April 26, 2015 01:33AM |
Re: Need to decide 5mm, 8mm or proper leadscrews April 26, 2015 05:30AM |
Re: Need to decide 5mm, 8mm or proper leadscrews April 26, 2015 06:02AM |
Re: Need to decide 5mm, 8mm or proper leadscrews April 26, 2015 09:48AM |
Re: Need to decide 5mm, 8mm or proper leadscrews April 26, 2015 10:19AM |
Re: Need to decide 5mm, 8mm or proper leadscrews April 26, 2015 11:19AM |
Re: Need to decide 5mm, 8mm or proper leadscrews April 26, 2015 11:56AM |
Re: Need to decide 5mm, 8mm or proper leadscrews June 10, 2015 02:04AM |
Re: Need to decide 5mm, 8mm or proper leadscrews June 10, 2015 08:34AM |
