Want to verify the 3d plastics part I need for the Prusa Mendel i2.
July 13, 2015 11:05PM
ok so this will be my first 3d printer, and I am planing to buy the "Prusa Mendel i2 Kit (No Plastics)" from easyreprap.com and I wound like to verify the 3d plastics part I need to buy, I would like to buy then all at the same time.
so I will need
8 bar clamp from the metric-prusa-lm8uu folder
3 bearing-guide from the metric-prusa-lm8uu folder
4 belt-clamp from the metric-prusa-lm8uu folder
4 belt-clamp-nut-holder from the metric-prusa-lm8uu folder
2 coupling from the metric-prusa-lm8uu folder
3 endstop-holder from the metric-prusa-lm8uu folder
2 frame-vertex from the metric-prusa-lm8uu folder
4 frame-vertex-foot from the metric-prusa-lm8uu folder
2 rod-clamp from the metric-prusa-lm8uu folder
1 x-carriage from the metric-prusa-lm8uu folder
1 x-end-idler from the metric-prusa-lm8uu folder
1 x-end-motor from the metric-prusa-lm8uu folder
1 ybrac-t from the metric-prusa-lm8uu folder
3 y-bushing from the metric-prusa-lm8uu folder
2 z-motor-mount from the metric-prusa-lm8uu folder
then I need to run the generate-metric-prusa-lm8uu.sh to get the rest of the stl file that I will need.
Do all of this sound like all of the part I will need, am I missing anything. or is that all of the plastics part I will need to build the 3d printer.
Re: Want to verify the 3d plastics part I need for the Prusa Mendel i2.
August 04, 2015 12:15AM
The wiki should have all the info on printed parts in section 6, that's all that is needed for the main assembly. Also make sure to get the parts for your extruder.
