US-friendly squashed frog stencil
Posted by Buback
September 29, 2010 01:11PM
Could someone please scale the image to 8.5 x 11 paper and post it to the y-axis wiki page, please? I've been trying to do the scaling myself and getting more and more frustrated!
ARRRRRGGGHHHH!
Re: US-friendly squashed frog stencil
September 29, 2010 02:05PM
Not the workaround you are looking for, but most printers will take A4, and if you just need a few sheets, you can trim down a bit of legal size paper to 11.7 x 8.3 in. We use to do that when we had short run and nothing in stock.
I'll try to take a stab at what you are requesting, but could you toss me a link to the original version?
September 29, 2010 02:12PM
Here's nop head's simplified "squashed frog" blog post, but I don't see a file to convert. I assume you want to print one out on letter size paper, paste it to some store-bought MDF and "scroll saw" it out.
I've been bothered by the lack of a letter sized template myself, but I instead bought a laser-cut version on ebay, so it dropped off the to-do list.
September 29, 2010 02:49PM
Try the attached. I took an image from [repstrapbertha.blogspot.com] and brought it into gimp. Then I rotated it, merged it with a 8.5x11 layer, and printed it locally as a PDF. My printer is broken right now, so I can't verify it's the proper size.
Leave comments on the thread if it works.
My blog's Reprap feed: [blog.markbova.com]
I'm currently working on a stock Mendel build with a Seeeduino Mega and four Pololu A4983 stepper controllers.
open | download - trial-squashed-frog-letter.pdf (19.1 KB)
September 29, 2010 03:17PM
My file is here: [www.thingiverse.com] I don't understand why you need to scale it though. It should come out actual size, regardless of the paper size, assuming it fits on. I.e. it should always be printed 1:1
September 29, 2010 03:26PM
nophead Wrote:
> My file is here:
Nice, but that's on A4 paper. the OP's asking for something on Letter size paper.
September 29, 2010 03:32PM
pica Wrote:
> I assume
> it out.
Exactly. I knew I saw the simplified frog somewhere but it's not in the wiki, and I couldn't find a direct link or remember who posted about it. Should have known it was Nophead :-). At least now it can be found with a search of the forums, if all else fails.
It printed as 199.5 x 136.5 (close enough). The standard is listed as 148 mm wide, but I guess he just made it a bit narrower. All the cutouts check out though so this will be perfect.
I am very slow to anger, or even to annoy, but something about this just enraged me! Thank you so so much
September 29, 2010 03:41PM
nophead Wrote:
> My file is here:
a lot of programs think you want the image scaled to paper size, and give no option to print actual size. I even tried Gimp with a bunch of different settings and that was what frustrated me. (of course this was with the original, not yours)
The PDF works, however, so i'm happy now
