Hi guys,
i've just bought the
prusa i3 kit from the replikeo site.
I've assembled it and did the wirings as the instructions stated
here .
I've also uploaded the marlin firmware onto my arduino with the modified configuration.h for the RAMPS 1.4 as stated
here
All the motors and the thermistors work perfectly. However, the heater bed and the extruder do not heat up. Moreover, the fan doesn't work either.
Basically everything on the pins D08, D09, D10 doesn't work. I've tried controlling it with both Printrun and Repetier software.
Sometimes it just doesn't react, but sometimes I get the following error:
Error:Heating failed, system stopped!
Heater_ID: 0 Error: Printer halted. kill() called!
If you can take a look at my wiring (attached) or if you have any suggestions, i would appreciate that very much.
Thank you in advance!
open |
download -
(494.1 KB)
