Deactivate Probe and use end stops.. How? March 14, 2016 07:32AM |
Re: Deactivate Probe and use end stops.. How? March 27, 2016 08:46AM |
Re: Deactivate Probe and use end stops.. How? March 27, 2016 09:18AM |
cprich22
Hi all!
I recently just updated my melzi board on my Reprappro Mendel to the duet board. It's all working, moving and heating fine the z probe that i bought is also working.
However as I have the older machine that uses the end stops to home the x and Z my Mendel lacks the bit that breaks the beam on the x axis.
What I need is to deactivate the probe and make the printer home itself using the endstops so I can print out the new parts.
I attempted changing the homex code to basically match the homey on the SD image (as y still uses the end stop to home) but it didn't seem to do anything as the x carrage just collided with the end.
Is there another setting I need to change or if anyone has the older Mendel SD image. I'm not bothered about the probe not working as yet, just need to get my printer printing again.
Any help would be appreciated.
