Hi, I built my first printer and when I start it up for the first time I get the following error...
Error:0
: Extruder switched off. MAXTEMP triggered !
Error
rinter stopped due to errors. Fix the error and use M999 to restart. (Temperature is reset. Set it after restarting)
ok T:0.0 /0.0 B:0.0 /0.0 T0:0.0 /0.0 @:0 B@:0
and when i check the temperature it says...
ok T:453.1 /0.0 B:0.0 /0.0 T0:453.1 /0.0 @:0 B@:0
So my problem is the heater if reading 453 degrees without even being on and regardless of if the thermoster is plugged in or not. I'm well educated in the computer field but not electrical and wiring so I'm not sure what to do. I have a voltmeter and can do any troubleshooting necessary if someone could help me out with what I can do it'd be very much appreciated.
