Using M3 x25 cap screws instead of x20
Posted by Ollie
December 29, 2010 04:50PM
I'm finding it somewhat hard to get cheap M3 x20 screws ( i'm on a budget thumbs down), the cheapest i've found them is £11 for a pack of 100 :/.
But, i can get 200 x25's for little over £3.
Just going out on a whim here, but would it be possiblle just to use the x25's instead? Surely if it came down to it i could just saw off the extra 5mm surely?
Ollie.
Re: Using M3 x25 cap screws instead of x20
December 29, 2010 04:58PM
You won't have any problems for the most part, but the 25s will be too long to mount a motor to the standard brackets. You could cut them down or add spacers to take up the extra 5mm easily enough.
December 29, 2010 05:51PM
Thanks, that'll make my life easier cool smiley
December 29, 2010 06:05PM
That's what I did with my M3-25's.
FWIW: Put a normal M3 nut on the bolt before you cut. After some cleaning up of the end of the bolt and the thread, you should then be able to remove the nut. The act of removing the nut will help clean up any remaining thread problems, without trying to get a nut correctly aligned to the bolt thread.
Note: I have seen people do this with a die cutter, using the die cutter to cut the thread on threads badly damaged after cutting the bolt and then grinding the end smooth/straight. They were much larger threads than M3 though.
December 29, 2010 09:59PM
Yep cleaning up the threads after a cut is something you should practice before doing it on something crucial- like driving it's not hard but still needs some skill
Wooden Mendel
Teacup Firmware
December 31, 2010 09:31AM
Thanks for the info guys, just waiting for parts now. Not the best time to order them, but still a good start to 2011 smiling bouncing smiley
January 01, 2011 07:51AM
> 5mm surely?
> Ollie.
Try orbital fasteners listed on the BOM, I did the budget on there it's about £20 for all the fasteners.
January 04, 2011 03:35PM
Cheers
January 15, 2011 05:19AM
Try [www.modelfixings.co.uk] they are very good for odd sizes and prices are reasonable too.
Mike
