Tightness of Y axis
Posted by madscifi
Tightness of Y axis
January 01, 2011 06:25PM
How tight/smooth should the Y axis be? I'm uncertain if I need to make more adjustments or if the resistance I'm seeing is expected.
Assuming the belt is not attached and the Y axis is level, it should:
a. If pushed gently, it should glide all the way from one side to the other and only stop because it runs into the other side.
b. If pushed gently, it should glide a little ways but it should stop well before hitting the other side?
c. What is this gliding of which you speak?
Thanks,
--Jim
Re: Tightness of Y axis
January 01, 2011 07:18PM
It should be closer to A.
Bob Morrison
Wörth am Rhein, Germany
"Luke, use the source!"
BLOG - PHOTOS - Thingiverse
January 02, 2011 10:47AM
Assuming that the belt isn't connected, it should be closer to A.
Once the belt is connected the resistance of the motor will make is closer to C.
I'm building it with Baling Wire
January 02, 2011 01:56PM
Thank you both. I'll go back and see if I can get the axis bed set closer to A.
