The new guy January 18, 2011 06:43AM |
Re: The new guy January 18, 2011 07:16AM |
Re: The new guy January 19, 2011 11:07AM |
Re: The new guy January 20, 2011 07:06AM |
Re: The new guy January 20, 2011 07:15AM |
Qbert
I have had a good look at the gcode in some simple files (Monolith_small). there are some missing M codes in RepRapWiki that I don't see in the code (M101 & M103). If I had to guess what they were I would say turn on and off the extruder motor, is this right?
M101 Turn extruder 1 on Forward. M102 Turn extruder 1 on Reverse. (?) M103 Turn all extruders off. M104 S145.0 Set Extruder 1 target temperature to 145.0 C. M105 Custom code for temperature reading. (Not used) M106 Turn fan on. M107 Turn fan off. M108 S400 Set Extruder 1 speed to S value/10 = 40rpm. M201 Turn second extruder on Forward. M204 S145.0 Set Extruder 2 target temperature to 145.0 C M208 S400 Set Extruder 2 speed to S value/10 = 40rpm. M210 AUX 1 off M211 AUX 1 on M220 AUX 2 off M221 AUX 2 on M222 Set speed of fast XY moves M223 Set speed of fast Z moves M224 Enable extruder motor during fast move M225 Disable extruder motor during fast move M226 Pause the printer until ESC key is pressed M227 S1000 P800 on extruder stop (M103) reverse the extruder stepper for S turns and on extruder start (M101) M228 - Disable M227 M229 - Same as M227 but P and S parameters specify prime and reverse extruder thread revolutions (not stepper steps) M301 Turn extruder 3 on Forward. M304 S145.0 Set target temperature of extruder 3 to 145.0 C M308 S400 Set Extruder 3 speed to S value/10 = 40rpm. (Note to turn off extruders 2 and 3 use M103 which turns off all extruders) M542 - Enter 3000 nozzle wipe / move to RapMan rest location M543 - Exit 3000 nozzle wipe / does nothing on RapMan M551 / M552 / M553 - Prime extruder 1 / 2 / 3. Parameter P = stepper steps, S = RPM * 10 M561 / M562 / M563 - Reverse extruder 1 / 2 / 3. Parameter P = stepper steps, S = RPM * 10
M108 S ;M108 S M101 ;M101 M103 ;M103 M105 ;M105
Re: The new guy January 20, 2011 07:53AM |
Re: The new guy January 20, 2011 09:15AM |
