Electronics....software....issues January 22, 2011 09:28AM |
Re: Electronics....software....issues January 22, 2011 10:25AM |
HereIgoAgain
According to the literature with the "mostly assembled parts" I received it says "The extruder controller and motherboard have be pre-programmed with the MakerBot firmware and Arduino bootloader", does this mean I don't have to push out software to the motherboard ?? and is this the same software that the MENDEL uses or is it different. Can I go thru the same checkout lists provided in the wiki's for all of the electronic components and is it ok to just use the RJ45 connector on the motherboard to a 4 pin connector on the opto switch. I anxiously await some sage advice
Re: Electronics....software....issues January 22, 2011 09:33PM |
