HI Thanks for reading my post.
After many years I've decide to resurrect my reprap and have slowly gotten parts of it moving again. However I'm having some issue with the axis movments.
Here's the history,
My reprap previously ran a Sanguino with Sprinter. However over time it destroyed the bed traces and eventually one of the chips burnt out. As such I'm now replacing it with Ramps and Marlin firmware.
After much work I have the X and Y axis working however now the z axis only moves in symetric amounts i.e if it moves 10mm down it can move 10mm up. But the down movement must come first.
It also ignores the endstop switch (mechanical) and won't HOME. The switch is definitely working as I've issued a M119 command in pronterface.
Also my extruder only works in 1 direction no matter whether i hit extrude or reverse.
Any help would be greatly appreciated.
Rob.
Edited 1 time(s). Last edit at 12/26/2016 10:16PM by tribesindustries.
