Nema 17 specs
Posted by owism8
Nema 17 specs
April 25, 2011 10:23PM
Hey reprappers,
Is the attached spec good for the mendel?
I got it from : www.osmtec.com
They gave the following quote:
100pcs: USD10
200pcs: USD9.5
500pcs: USD8.5
[omemon.wordpress.com]
open | download - 17HS13-0404S.pdf (429.2 KB)
Re: Nema 17 specs
April 26, 2011 01:53AM
That *might* be ok for the axes, but is definitely not strong enough for the extruder. My extruder motor has 5 kg*cm of torque, but it probably is a bit overkill. Most people seem to recommend 3 kg*cm for the extruder, and 1.5+ for the axes.
Help improve the RepRap wiki!
Just click "Edit" in the top-right corner of the page and start typing.
Anyone can edit the wiki!
Re: Nema 17 specs
April 26, 2011 04:05AM
You also want a lower voltage motor to work well with the constant current chopper drives that reprap uses, around 3V is good. With a 12V motor the on time would approach 100% causing the chopper frequency to drop into the audio range.
