Just like any bearing out there.....PLA bearings WILL wear out.
Many factors will determine how long any bearing will last. Here are just a few to consider.
-bearing material
-Speed you run the machine
-Weight on the bearing
-quality of the smooth rod.
-type of lube you are using
-machine adjustment
-aging of the bearing material
I see reprap prusa with the PLA bearings as a GOOD stepping stone into the hobby. You can also upgrade the machine as you go.
The more you use it..... the print quality will go down, but if your ok with rebuilding and replacing bearings when the print quality goes down its not bad option to get you printing.
In my low cost unit under development I'm using LM8UU linear bearings. They are good, cheep and they work amazing.
