Prusa github stl hole sizes too large? June 20, 2011 01:08PM |
Re: Prusa github stl hole sizes too large? June 20, 2011 02:12PM |
Admin Registered: 17 years ago Posts: 7,879 |
//[m8_dia, m8_nut, m4_dia, m4_nut, m3_dia, m3_nut, bush_dia, mot_shaft, bush_rod, bush_outerdia, bush_length] [8.6, 15.4, 4.8, 8.5, 3.8, 7, 11, 5.2, 8.2, 16, 11],//metric
Re: Prusa github stl hole sizes too large? June 20, 2011 05:11PM |
Re: Prusa github stl hole sizes too large? June 20, 2011 06:04PM |
Re: Prusa github stl hole sizes too large? June 21, 2011 01:25AM |
nophead
Its because people tend to tune their models to suit their machines, rather than tuning their machines to make accurate renditions of their models.
Re: Prusa github stl hole sizes too large? June 21, 2011 02:27AM |
The idea is Super
Generation 7 Electronics | Teacup Firmware | RepRap DIY |
Re: Prusa github stl hole sizes too large? June 21, 2011 02:37AM |
Re: Prusa github stl hole sizes too large? June 21, 2011 03:43AM |
Traumflug
but there's not even a suitable procedure in the Wiki.
Re: Prusa github stl hole sizes too large? June 21, 2011 05:01AM |
Re: Prusa github stl hole sizes too large? June 21, 2011 08:32AM |
Re: Prusa github stl hole sizes too large? June 21, 2011 02:01PM |
The problem is we're not quite there yet, but some people seem to think that, and complain a lot about it.
Re: Prusa github stl hole sizes too large? June 21, 2011 02:42PM |
Re: Prusa github stl hole sizes too large? June 21, 2011 04:34PM |
Re: Prusa github stl hole sizes too large? June 21, 2011 05:28PM |
Re: Prusa github stl hole sizes too large? June 21, 2011 05:41PM |
Re: Prusa github stl hole sizes too large? June 21, 2011 07:22PM |
YES, that is the main problem!
Re: Prusa github stl hole sizes too large? June 22, 2011 05:02AM |
Re: Prusa github stl hole sizes too large? June 22, 2011 06:55AM |
Re: Prusa github stl hole sizes too large? June 23, 2011 03:05AM |
The main reason holes come out way too small is due to segment pausing, which I have never suffered from because I use 100Mb Ethernet instead of serial over USB..
Even if the machine is perfectly calibrated, holes will still come out too small.
Re: Prusa github stl hole sizes too large? June 23, 2011 04:16AM |
Re: Prusa github stl hole sizes too large? June 23, 2011 05:50AM |
//[m8_dia, m8_nut, m4_dia, m4_nut, m3_dia, m3_nut, bush_dia, mot_shaft, bush_rod, bush_outerdia, bush_length] [8.2,15.5,4.5,8.6,3.5,6.8,11,5.2,8,16,11],//metricNot too far off nopheads. I have the M8 hole diameter small so I can drill it out. As I have a Bowden cable, I always end up with a blob on each layer as it stops and retracts (perhaps I should change the path order from Loops > Perimeter > Infill to Perimeter > Loops > infill?), so have to drill it out anyway. I don't seem to have observable segment pauses, but looking at the stls and the path Skeinforge produces, I would say there are 13 facets on a 8mm and 6 facets on a 3mm hole.
