Hi everybody,
I'm building my first RepRap - Prusa, and I'm not sure which belts are pulleys designet for. I have found company which sells belts, but they have
types T5 and AT5. The AT5 belt has a bit longer teeth with shorter round shaped spaces in oposite to T5 profile, which has aproximately 1:1 ratio tooth:space and teeth are more rectangular (both belts have the right 5 mm pitch).
When I take a closeup look at the pulley, it seems to me, that teeth on it respond more to AT5 profile, but I'm not sure.
2nd question: They sell standard width of belt 6 mm (in Prusa BOMs is usually written 5mm width).
Is 6 mm width problem if the space between bearing washers (the large ones) is 9 mm on my machine in build?
Thanks for help in advance
Jakub
