I'm having problems with my thermistor and RepSnapper. I recently broke the thermistor so I put a new one on my heating block. I connected it all up and started RepSnapper.
I knew I needed to edit the thermistor table information to match the new thermistor, so I did that and compiled and reloaded the firmware.
However, the" current temp" box on the RepSnapper Print tab doesn't show the temperature correctly. It shows numbers round 639B, 723B, 780B, 663B, etc, etc. When I hold the block it doesn't seem to register any increase in temperature (from my body heat).
I even made another completely new heating block with a different thermistor (with different thermistor table information) but the same thing happens.
The thermistor table information I change is in the "temperature.h" file
Does anyone recognise this problem?
Am I doing something basically stupid?
Thanks
Pete
Edited 1 time(s). Last edit at 10/03/2011 06:35AM by Flackster.
