diegudios printer - looking for economical strength January 07, 2013 07:25PM |
Re: diegudios printer - looking for economical strength January 08, 2013 06:33AM |
| Generation 7 Electronics | Teacup Firmware | RepRap DIY |
Re: diegudios printer - looking for economical strength January 08, 2013 05:49PM |
Re: diegudios printer - looking for economical strength January 09, 2013 07:27AM |
I imagine that the Gen6 that you mentioned
the package of 3 guides and the skids (12) cost 90€ including cutting and delivery... It would be great to find something cheaper...
Re: diegudios printer - looking for economical strength January 09, 2013 10:58AM |
Re: diegudios printer - looking for economical strength January 09, 2013 01:09PM |
I mentioner Gen7, not Gen6. Gen7 is DIY-able, Gen6 is designed for industry production.
Drawer slides are surprisingly good if you restrict their movement. They have two sets of linear bearings forming a telescopic structure, the larger set are good, the smaller set I found are not stiff enough so you need to fix them relative to the large bearing.
Re: diegudios printer - looking for economical strength January 09, 2013 01:19PM |
Re: diegudios printer - looking for economical strength January 10, 2013 04:30AM |
Re: diegudios printer - looking for economical strength January 10, 2013 08:47AM |
I've seen a very nice 40mm wide drawer slide in my local "construction" store (Baumax), but they costed 24€ each
Re: diegudios printer - looking for economical strength January 10, 2013 01:54PM |
I have had great success using stainless steel rods (not precision ground, just good quality) and removing the centres from normal bearings to use as bushings. I just make sure there is always a big blob of grease trapped between each pair of bearings on a slider.
Re: diegudios printer - looking for economical strength January 12, 2013 06:31PM |
