golemD released!
Posted by yru
yru
golemD released!
August 28, 2013 07:18PM
I finally cleaned up files enough for a decent release. so enjoy and feedback me plenty.
it's cheap to make and comes with chamber as standard with no additional cost ;p
[www.thingiverse.com]
Re: golemD released!
August 28, 2013 08:28PM
Is there any difficulty holding temperature in the chamber with the slots down the sides?
yru
August 29, 2013 05:57PM
with only heat from the bed I got to 50-60C within chamber and you could barely feel heat coming out of the upper and side slots ("plastic melting smell" zone is also reduced - 2-3m vs 30cm from printer). I guess it's due to absence of holes in the bottom of the chamber so no place to suck cold air from and no convection. The is always an option to put rubber seal - lip like contraptions within those slots but i don't think it will be necessary unless you direct some external airflow into them.
Also executing fume venting or filter is quite easy.
January 18, 2014 01:51PM
I can imagine adding brushes or rubber sides in the sideslots will isolate the slots very well.
