"Ola", the RepOlaRap. January 07, 2010 11:36AM |
Re: "Ola", the RepOlaRap. January 07, 2010 06:51PM |
Admin Registered: 19 years ago Posts: 1,791 |
Re: "Ola", the RepOlaRap. January 07, 2010 09:34PM |
Re: "Ola", the RepOlaRap. January 07, 2010 10:11PM |
Re: "Ola", the RepOlaRap. January 08, 2010 04:58PM |
Re: "Ola", the RepOlaRap. January 08, 2010 08:26PM |
Re: "Ola", the RepOlaRap. January 08, 2010 08:51PM |
Re: "Ola", the RepOlaRap. January 09, 2010 01:55PM |
Re: "Ola", the RepOlaRap. January 10, 2010 08:09AM |
Re: "Ola", the RepOlaRap. January 10, 2010 05:38PM |
Re: "Ola", the RepOlaRap. January 11, 2010 01:22PM |
Re: "Ola", the RepOlaRap. January 11, 2010 05:56PM |
Re: "Ola", the RepOlaRap. January 12, 2010 12:36PM |
Re: "Ola", the RepOlaRap. January 12, 2010 01:28PM |
Re: "Ola", the RepOlaRap. January 12, 2010 03:11PM |
Admin Registered: 19 years ago Posts: 7,883 |
Re: "Ola", the RepOlaRap. January 16, 2010 07:53AM |
Re: "Ola", the RepOlaRap. January 16, 2010 09:44PM |
Re: "Ola", the RepOlaRap. January 17, 2010 06:35PM |
Re: "Ola", the RepOlaRap. January 18, 2010 12:17AM |
Re: "Ola", the RepOlaRap. January 18, 2010 10:08AM |
Re: "Ola", the RepOlaRap. January 18, 2010 11:18AM |
Re: "Ola", the RepOlaRap. January 18, 2010 11:30AM |
Re: "Ola", the RepOlaRap. January 22, 2010 08:27PM |
Re: "Ola", the RepOlaRap. January 22, 2010 10:11PM |
Re: "Ola", the RepOlaRap. January 23, 2010 01:33AM |
Re: "Ola", the RepOlaRap. January 23, 2010 12:44PM |
Re: "Ola", the RepOlaRap. January 28, 2010 10:21PM |
The steppers are mounted. I've attached a 4 line screw junction on the radial arm platform, and wired the top motor to that. I have a ~40 cm long 4 wire CAT3 phone cable (AWG 24 - after studying the ohm/ft readings, it should be fine in open air) for that motor, terminating in an RJ25 plug. I've also modified two MakerBot stepper motor controllers by adding wires to the underside and terminating into an RJ25 jack. (The plugs were $10 for 25, the plugs about $23 for 10) I may eventually swap out the cables with a bit larger, twisted pair, stranded lines if these end up being too noisy or heat up too much.
