low cost fabbed 3-axis mill from makezine
Posted by bobt
January 12, 2010 11:07PM
[blog.makezine.com]
Bob Teeter
"What Box?"
Re: low cost fabbed 3-axis mill from makezine
January 12, 2010 11:31PM
Seems awfully expensive ($500) considering the time to make it and it's limitations. I have seen the sears cnc for $750 at various times using promotions and a coupon. The mcwire is the same or less and seems to be quite a bit more flexible?
A couple of the parts are unusually high end ($14 bearings), possibly you could substitute with much cheaper options and then that would really be something.
January 13, 2010 12:16AM
He's working with folk towards a larger machine, which is promising.
It would be interesting to hash out a self-replicating type cnc-router machine like
buildyourcnc.com
Only GPL. I don't know if Jonathan Ward is going towards that, but RepRappers could.
January 13, 2010 11:45AM
If anyone wants to build one, here are the designs:
[mtm.cba.mit.edu]
In the video he says "Three to four hundred dollars". The BOM shows a total material price of $458.18 and that's only the mechanicals (no electronics).
January 13, 2010 11:54AM
He likely had some of the components just sitting around. He likely ment "We had to go buy 3-400 dollars worth of stuff", stead of "It will cost YOU 3-400 to make".
repraplogphase.blogspot.com
January 13, 2010 05:22PM
I've been wondering how interested he is in engaging the RepRap community, if at all.
Here's a cute machine, btw.
[mtm.cba.mit.edu]
Also, I don't mind doing some cheerleading to see if they're willing to check their work into RepRap's wiki, so we can hack on it.
Edited 1 time(s). Last edit at 01/14/2010 05:00PM by SebastienBailard.
January 14, 2010 05:08PM
I'll email Jonathan Ward and the other folk and see if they're interested in copying their stuff up onto RepRap.org. It would help a bit, although folk would probably immediately scramble trying to use cheap machine elements off of ebay and so on.
January 15, 2010 04:13AM
Actually, I'm going to make sure we have a decent stub for Tim's TimBot:
[objects.reprap.org]
McWire,
and
up there, so Jonathan will feel as though he's contributing to an existing library of machines, rather than us trying to freeload off his work because it's trendy.
We do need a CNC-router fabricable RepStrap up on RepRap.org, though, and it's silly to have to reinvent it.
We'll coordinate that work here:
[dev.forums.reprap.org]
TimBot is a nice-looking machine, by the way. That's (my place holder name for Tim/Bothacker's name, which is really called ... ?)
[bothacker.com]
Edited 2 time(s). Last edit at 01/15/2010 04:24AM by SebastienBailard.
February 05, 2010 02:06PM
> which is promising.
I like the compact nature of it (all cut from one 2'x4' sheet of 5-ply), but $450 for mechanicals alone seems a bit stiff. Nearly 25% of the cost goes to 8 bearings.
Personally, I'd be interested in a cost-reduced version as a priority over just a larger version.
-ethan
February 07, 2010 05:32AM
I see the frame but where is the electronics?
* homeprototype free 3d design repository
* Blog
* Google+
