Conveyor belt as Y-axis March 24, 2010 05:12PM |
Re: Conveyor belt as Y-axis March 24, 2010 05:29PM |
Re: Conveyor belt as Y-axis March 25, 2010 02:08AM |
Re: Conveyor belt as Y-axis March 25, 2010 03:23AM |
Re: Conveyor belt as Y-axis March 25, 2010 04:46AM |
Re: Conveyor belt as Y-axis March 25, 2010 05:20AM |
Then you must have seen how huge his vacuum pump was and it was insufficient to hold down the kapton tape, so no - I don't think it will work since the force exerted by a large object on the outer edges is very strong.Quote
atorox
I have seen this but if the belt is kept in tension with sprockets and axles I was hoping that a lower vacuum would be enough to keep the belt flat. And on the other hand the vacuum can not be so strong that it hinders belt movement.
Re: Conveyor belt as Y-axis March 25, 2010 05:31AM |
Admin Registered: 18 years ago Posts: 7,883 |
When the film is flat any horizontal pull produces no vertical component at the centre, unless the centre is displaced upwards. Say we wanted no more than 0.25mm lift from a force of say 10N with a bed 100mm wide. A vertical displacement of 0.25mm at a distance 50mm from an edge would stretch the length by 2 * (sqrt(50^2 + 0.25^2) - 50), which is only 0.00125mm. So the mechanical advantage is about 200:1, so you would need a tension of 2000N just to get it nearly flat.
Re: Conveyor belt as Y-axis March 25, 2010 12:56PM |
Re: Conveyor belt as Y-axis March 25, 2010 01:06PM |
WOOD does not contract.
Re: Conveyor belt as Y-axis March 25, 2010 01:26PM |
Re: Conveyor belt as Y-axis March 25, 2010 02:25PM |
And still I can't get over the idea that if the belt is kept tight over the bed and a low vacuum is added inth equation the belt and extruded plastic should keep straight enough.
What don't you understand about the simple applied maths I presented above?|
Re: Conveyor belt as Y-axis March 25, 2010 02:57PM |
Re: Conveyor belt as Y-axis March 25, 2010 04:13PM |
Re: Conveyor belt as Y-axis March 26, 2010 01:40PM |
Re: Conveyor belt as Y-axis March 31, 2010 07:30PM |
Re: Conveyor belt as Y-axis March 31, 2010 07:50PM |
