e3d volcano extruder
November 01, 2015 06:23PM
Hello i am making a 400x400 build volume extrusion based printer similar to the folgertech design but enlarged. In a effort to reduce print times I’m going to run a e3d volcano and switch between the .4-1.2mm tips as needed. From other reviews I’ve read most extruders can’t keep up with the flow rate of the 1.2mm. Planing on using 1.75 filament but don’t know where to look for a high speed extruder that will last. I have also already ordered a 45Ncm stepper. any information is greatly appreciated this will be my first build and learning a lot along the way.
Re: e3d volcano extruder
November 02, 2015 04:56PM
I need this information also.... I have asked in another thread but did not get responses that were based on experience with the volcano and 1.2mm nozzles.
Other Thread
We may need to do some testing..... with geared motors and dual sided and geared hobs, the testing could get expensive.....
November 02, 2015 05:17PM
I had looked through that thread at some point but it seams everything is opinions and not any real kind of stats to go off of.
Someone pointed me towards the printrbot dual drive and it looks great for the grip to push it through just dont know if it could keep up with the larger 1.2 flow rate.
November 03, 2015 03:13PM
Also, I contacted PrintrBot support about using their setup for a bowden drive. They said that they figured it would work, but had never tried it. Might be a pain in the butt to machine a place to connect the fitting....
I wish someone would review all of the options scientifically. I would volunteer, but buying all the options would cost about $1000... too much.
September 07, 2017 11:32PM
patrickrio
whatever you do don't use a bowden for such high-pressure, high-flow arrangements. the amount of buckling (as evidenced by the absolutely massive "retract" distances recommended) is enormous as it is.
one thing that doesn't seem to be well-understood is that a 3mm really does need far more pressure from the drivegear than a 1.75mm. i've got a question outstanding on stackexchange where i'm investigating it "formally" so to speak. [math.stackexchange.com]
with the extra pressures you're considering, you really should be considering a geared (and a direct) drive mechanism *even with 1.75mm filament*. that usually means extra weight on the carriage, which would normally reduce top speed, but you can put in a flex3drive to deal with that. however as the pressures are still quite high you still might also wish to look at a geared extruder (3:1 or 4:1)... *AND* still use a Flex3Drive which has a 40:1 wormdrive in it, so as not to put too much torque on the wormdrive. the easiest way to do all that would be to get one of these: [flex3drive.com]
basically you're looking at unchartered experimental territory, whatever you do here.
