Nitro´s A.R.P.E.G. 230°C Chamber printer for PPSU April 04, 2019 10:03PM |
Re: Nitro´s A.R.P.E.G. 230°C Chamber printer for PPSU April 05, 2019 04:42AM |
Re: Nitro´s A.R.P.E.G. 230°C Chamber printer for PPSU April 05, 2019 07:07PM |
Pippy
NitroFreak
SInce we had a severe time constraint during the competition, some parts are not built quite up to spec or visual pleasure.
Quite the opposite, I find all the engineering extremely visually pleasing myself.
Really nice!
Oh to have the tools to build a nice machine.
Re: Nitro´s A.R.P.E.G. 230°C Chamber printer for PPSU April 07, 2019 11:06PM |
Re: Nitro´s A.R.P.E.G. 230°C Chamber printer for PPSU April 08, 2019 08:08PM |
CinciCliff
Max,
Thanks for sharing! This is a fantastic build! Great engineering and fabrication! I hope you do well with the competition! Please let us know how you do?
What integrated servo drive are you using for the Y?
Cliff
Re: Nitro´s A.R.P.E.G. 230°C Chamber printer for PPSU April 15, 2019 09:05PM |
Re: Nitro´s A.R.P.E.G. 230°C Chamber printer for PPSU April 15, 2019 09:32PM |
Re: Nitro´s A.R.P.E.G. 230°C Chamber printer for PPSU April 16, 2019 05:08AM |
Re: Nitro´s A.R.P.E.G. 230°C Chamber printer for PPSU April 16, 2019 06:57AM |
Re: Nitro´s A.R.P.E.G. 230°C Chamber printer for PPSU April 19, 2019 01:52PM |
Re: Nitro´s A.R.P.E.G. 230°C Chamber printer for PPSU April 28, 2019 01:26PM |
Re: Nitro´s A.R.P.E.G. 230°C Chamber printer for PPSU May 02, 2019 08:05PM |
Re: Nitro´s A.R.P.E.G. 230°C Chamber printer for PPSU July 03, 2019 08:43AM |
Re: Nitro´s A.R.P.E.G. 230°C Chamber printer for PPSU July 14, 2019 03:08PM |
Re: Nitro´s A.R.P.E.G. 230°C Chamber printer for PPSU August 10, 2019 04:41PM |
Hespo
Congratz on this machine, nice piece of engineering!
Can i ask how you made the gantry insulators? what material are they made of? Do they insulate enough to keep the top cool without extra cool air?
Did you add extra seals to close those gaps around your z axis? I see you have 2 long thin gaps, i seem to remember a pic of a stratasys printer where they use some kind of seal which opens up when the z axis slides through it.
What insulation did you use for the static parts (like the walls)?
greetings,
Jens
Re: Nitro´s A.R.P.E.G. 230°C Chamber printer for PPSU August 10, 2019 04:45PM |
leadinglights
Hi NitroFreak
Can I ask if you have had any better luck with the vacuum hold-down system? I note that you said that you PEI sheets were deformed by the vacuum and that you then used glass. Have you tried again since to optimes this.
Mike
Re: Nitro´s A.R.P.E.G. 230°C Chamber printer for PPSU August 10, 2019 05:08PM |
Re: Nitro´s A.R.P.E.G. 230°C Chamber printer for PPSU August 11, 2019 09:04PM |
Re: Nitro´s A.R.P.E.G. 230°C Chamber printer for PPSU August 12, 2019 04:25AM |
Re: Nitro´s A.R.P.E.G. 230°C Chamber printer for PPSU September 12, 2020 05:42PM |
NitroFreak
Hespo
greetings,
Jens
Hi Jens, thank you!
The insulator is made from aluminum coated fiberglass. They sell it as welding protection mats. It is not the perfect material, i would wish for some teflon coated fabric of some kind. I´m talking to some suppliers that have something like i would want that is also a bit thinner and stiffer.
I originally planned to include strips of silicone that closed the gap, but it proved to not be necessary since the slit is so small (~8mm) that, with taking the insulation into account, there is almost no air escaping. I´ve held my hand there and could not feel any warm air moving. The Z axis is essentially at room temperature. The Titanium connection plates make an amazing thermal separator, i could put my finger about 2cm from the oven wall on the titanium plate and it would only be luke warm, despite being at over 200C three centimeters further into the chamber.
For the static parts i reused the original insulation that came with the oven. It is some stone wool or something similar, very ordinary. 220C is nothing special for a normal baking oven.
Re: Nitro´s A.R.P.E.G. 230°C Chamber printer for PPSU November 04, 2020 01:31PM |
Re: Nitro´s A.R.P.E.G. 230°C Chamber printer for PPSU January 17, 2022 01:07PM |
Re: Nitro´s A.R.P.E.G. 230°C Chamber printer for PPSU January 17, 2022 02:01PM |
1zhangvic
Hi Max,
Very wonderful project you have completed here and congratulations for winning.
I was curious as to how you created the folds in the bellow (fiberglass fabric)? I am trying to do something similar but am unsure how to create those folds.
Thanks,
Victor
