LargeScaleAdditiveManufacturing...
December 16, 2019 01:33AM
Hi all,
I am about to build a 3d printer for large scale printing.
I am thinking to use Servos for X & Y axes and steppers for Z & extruder.
I am exploring how to connect servos to controller board like RAMPS/MKS/etc.. Any suggestions?
Also thinking on to control all axes using CNC servos and extruder through stepper but I don't know how to procees on this..
Can the CNC controller read gcode file prepared by slicing software for the axes movement only?
Anyone can help/suggest me in this....
Regards,
Prashant.
VDX
Re: LargeScaleAdditiveManufacturing...
December 16, 2019 02:39AM
... I'm using UHU servo drivers, which are controlled by STEP+DIR like common stepper drivers -- they receive the encoder signals and make "close loop" on their own.
There are other comercial drivers too with this capability ...
Viktor
December 16, 2019 02:47AM
VDX
That actually looks like a solution that isn't that expensive as well. What else would I need besides three stepper to servo UHU drivers? Is there more info to be found somewhere?
I'm currently building a newer machine at home and always wanted to try our servo motors!
http://www.marinusdebeer.nl/
VDX
December 16, 2019 04:35AM
... could be, the UHU drivers are only locally available (was a forum build) - but you can find some BLDC drivers at 'nanotec', that should do the same:
[us.nanotec.com]
Viktor
December 16, 2019 12:14PM
VDX
[us.nanotec.com]
Those are a factor 10 more expensive
VDX
December 16, 2019 01:59PM
... not really - paid 105€ for the assembled UHU drivers too -- but they are way "beefier" with 150Volts@10Amps, than the Nanotec ones grinning smiley
Viktor
December 16, 2019 11:53PM
Thats a lot of info guys...
But in general if I have to use Panasonic servo and its drives, how do I connect it on RAMPS board for X & Y axes?
Is there anyone who has done this?
Regards,
Prashant..
VDX
December 17, 2019 03:26AM
... do you have all the relevant connection infos (type, pinout, datasheet, ...) -- it's pretty hard to impossible to guess ...
Viktor
December 17, 2019 01:19PM
You need a fitting servo drive for the panasonic servo. In the datasheet of the servo drive you will find the relevant control directions.
I would suggest reading up on it yourself as it is not as straightforward as plugging in steppers into a ramps board, as you will also have to tune the servos.
Google knows everything. I suggest finding a suitable servo drive and just reading the manual.
