Possibly building 3D printer - seek a bit of advice ... May 09, 2023 07:47AM |
Re: Possibly building 3D printer - seek a bit of advice ... May 09, 2023 06:52PM |
Re: Possibly building 3D printer - seek a bit of advice ... May 10, 2023 09:16AM |
Re: Possibly building 3D printer - seek a bit of advice ... May 10, 2023 01:34PM |
Re: Possibly building 3D printer - seek a bit of advice ... May 10, 2023 09:19PM |
Re: Possibly building 3D printer - seek a bit of advice ... May 11, 2023 12:05PM |
Re: Possibly building 3D printer - seek a bit of advice ... May 11, 2023 12:18PM |
Re: Possibly building 3D printer - seek a bit of advice ... May 11, 2023 04:41PM |
IMO it's absolutely revolutionary and I can't believe it hasn't taken the community by storm yet. I have one on my SCARA printer, which is a rather flimsy machine so not the best for precision testing, but it works a lot better than the bowden extruder I originally had on it. You must use ABEC-5 or better bearings or it won't follow the helix on retraction. The carrier can be printed with integral posts and use 3mm coarse thread screws to hold the bearings on, rather than the expensive shoulder screws. It takes some trial and error to get the dimensions to come out just right, but 3D printing is repeatable enough that you can make .001" changes to the blade penetration depth and it makes a clear difference.Quote
evalon
I will comment below but while I remember it: I noticed in the "screwstruder" thread that you had commented there: With this in mind - did you ever try out this extruder type yourself? And, if so, did you find it to be "excellent" - or did there appear to be maybe some "systematic" shortcomings? I may of course ask rq3 himself but since we are in contact now I thought I would ask you here ...
Yeah, that will be just as troublesome on 3D prints. Even on thicker prints, the bottom tends to be very slightly convex after cooling and releasing from the glass bed. And horizontal dimensions on the first few layers are tricky because there's such a fine line between failing to adhere to the bed and smushing out so much that you get "elephant's foot". Although in my case that's mostly due to the fact that neither of my printers has a perfectly flat bed or a bed probe for mesh leveling, so I have to level them to where the lowest point will still adhere, and everything else gets smushed a bit.Quote
evalon
Regarding milling the 3D printed objects to size, yups, it could be an option - but usually the key objects I work with are very thin (2-5 mms) and "wide" (~100*100mm, or bigger) - and I need them to be absolutely flat (in some cases better than 1/100 mm). IME not easy to accomplish even on a good CNC mill since essentially all the feasible materials I have tried tend to bend due to internal material stresses. Fastening the materials in a way so that they do not become stressed is another challenge. I reckon something similar will happen with 3D printed materials and expect to try out mild annealing in due time and likely lapping machine sanding. In this context I also reckon your "horisontal expansion" setting may come in handy
Great idea! I wonder if a guitar tuner could be adapted as a dirt cheap worm gear... I may try that on the next revision of my SCARA.Quote
the_digital_dentist
If you're interested in building a tall printer, a belt lifted z axis can be made to work easily and probably more cheaply than if you use screws to do the lifting. A worm gear drive with a 30:1 (or more) drive ratio will stop the bed or XY stage from dropping when power is cut.
Re: Possibly building 3D printer - seek a bit of advice ... May 12, 2023 11:15AM |
Re: Possibly building 3D printer - seek a bit of advice ... May 14, 2023 05:03PM |
Re: Possibly building 3D printer - seek a bit of advice ... May 15, 2023 02:22PM |
Re: Possibly building 3D printer - seek a bit of advice ... May 23, 2023 09:31AM |
Re: Possibly building 3D printer - seek a bit of advice ... May 23, 2023 07:52PM |
Re: Possibly building 3D printer - seek a bit of advice ... March 27, 2024 03:13PM |
