Open sorce laser sintering with heated build chamber and piston. April 01, 2015 05:29PM |
Re: Open sorce laser sintering with heated build chamber and piston. April 03, 2015 11:15PM |
Re: Open sorce laser sintering with heated build chamber and piston. April 04, 2015 06:41AM |
Re: Open sorce laser sintering with heated build chamber and piston. April 09, 2015 03:05AM |
Lukas Hoppe
I was indeed planning to use a visible laser, in fact I have already one sitting on the desk in front of me. Therefore the glass should not be too much of an obstacle as the laser remains in a constant 90 degree angle to the sheet of glass. And as the laser diode I am intending to use delivers as much as 2 watts, there is plenty of power.
Lukas Hoppe
As far as the X/Y gantry goes, I was actually planning on using the standard 8mm linear motion hardware that Repraps use
Re: Open sorce laser sintering with heated build chamber and piston. April 09, 2015 10:05AM |
Re: Open sorce laser sintering with heated build chamber and piston. April 09, 2015 04:30PM |
Re: Open sorce laser sintering with heated build chamber and piston. April 09, 2015 05:09PM |
Re: Open sorce laser sintering with heated build chamber and piston. April 09, 2015 05:29PM |
Re: Open sorce laser sintering with heated build chamber and piston. August 30, 2015 09:19PM |
Re: Open sorce laser sintering with heated build chamber and piston. August 30, 2015 11:45PM |
Re: Open sorce laser sintering with heated build chamber and piston. August 31, 2015 06:14AM |
Re: Open sorce laser sintering with heated build chamber and piston. August 31, 2015 09:28AM |
Re: Open sorce laser sintering with heated build chamber and piston. August 31, 2015 03:10PM |
Re: Open sorce laser sintering with heated build chamber and piston. August 31, 2015 05:15PM |
Re: Open sorce laser sintering with heated build chamber and piston. August 31, 2015 06:47PM |
Re: Open sorce laser sintering with heated build chamber and piston. August 31, 2015 08:55PM |
Re: Open sorce laser sintering with heated build chamber and piston. August 31, 2015 11:12PM |
