Current projects for SLS / SLA / powder printers and what I've learned so far April 07, 2015 08:57AM |
Re: Current projects for SLS / SLA / powder printers and what I've learned so far April 07, 2015 05:40PM |
Re: Current projects for SLS / SLA / powder printers and what I've learned so far April 08, 2015 03:28AM |
That's why I needed a list. And the CandyFab with hot air melting sugar is quite interesting too.
But it seems there are tons of patents filed in this field all the time. I hate patents! Quote
Lukas Hoppe
I also wanted to give a few quick thoughts on the coloring of the sintered object with inkjet technology:
I believe that coloring before sintering would be problematic, because the different colors would vary the heat absorption. While this could be counteracted by programming the laser power to match the absorption of the specific color, there might be an even bigger challenge: the temperature inside the build chamber of an SLS machine might melt the plastic ink jet cartridges. This immense heat is also the reason why I separated the laser and XY gantry from the print chamber by a sheet of glass in my design.
Re: Current projects for SLS / SLA / powder printers and what I've learned so far April 24, 2015 05:50PM |
Re: Current projects for SLS / SLA / powder printers and what I've learned so far April 25, 2015 07:13AM |
Polyforge (www.polyforge.com)
20W CO2 Laser
Laser speed 120+ mm/s
Variety of build materials (and colours), so far tested with Nylon from several suppliers
195 mm x 195 mm x 195 mm build volume
