Cabine temperature for ABS powder sintering/welding?
Posted by yoda
October 22, 2015 08:34AM
Hi folks,
I have read the article in the reprap wiki where it is stated that the laser power is less important if the cabine or the powder bed is heated sufficient.
[www.reprap.org]
It is saying that nylon powder is heated until about 8 degrees below melting point. I am in the process of building a SLW/SLS printer and I would like to try with ABS.
Can someone tell me how much the cabine or the powder needs to be heated with ABS powder?
Regards,
Markus
VDX
Re: Cabine temperature for ABS powder sintering/welding?
October 22, 2015 09:51AM
... as most warping is received while cooling down from 50degC to roomtemp, I'll heat the chamber only for 55 to 60degC and use a laser with more power than 140mW winking smiley ... so the build chamber materials and nearby parts didn't suffer from overheating ...
Viktor
