300.0 mm of filament used in this print
Posted by julianh72
November 21, 2011 07:50AM
Sorry if this is answered elsewhere - can someone tell me how to activate / calibrate the calculation of how much filament is used in a print? I am using SFACT / Pronterface. Whenever I load an STL, the skeining process always finishes with a block of text something like:
the print goes from 24.246 mm to 151.254 mm in X
and is 127.008 mm wide
the print goes from 55.719 mm to 111.681 mm in Y
and is 55.962 mm wide
the print goes from -200.0 mm to 26.1 mm in Z
and is 226.1 mm high
The dimensions all seem reasonable; but the problem is - ALL of my prints are calculated to use 300.0 mm of filament!
Follow my Mendel Prusa build here: [julianh72.blogspot.com]
Re: 300.0 mm of filament used in this print
November 21, 2011 11:54AM
Erm, i believe your Z axis should not be going into the minus.
A minus means it's going to put your extruder head THROUGH your print bed... It looks like the model is not centred...
As for the statistics on usage etc, I ignore them myself because I've never got them to calculate correctly under repg...
November 21, 2011 04:12PM
> into the minus.
> is not centred...
Yeah, I noticed that as well. Since I don't know where the code is generated, I can't fix it!
But the prints are fine. It always reports my prints as starting at -200.0 mm, but it actually starts at 0.0 mm (as expected), and the print is actually 26.1 mm high, not 226.1 mm.
November 24, 2011 01:03PM
Perhaps you have some kind of homing code that is moving your z axis -200 units to find the min endstop? (I'm guessing in start.gcode?)
November 24, 2011 11:24PM
I usually ignore what Pronterface says since I got used to looking at the Skeinforge output in the console. But not that you mention it, the info from Proterface doesn't agree with Skeinforge. It's wrong.
