Skeinforge settings for a svg without toolpath
Posted by atztek
January 07, 2010 08:48AM
Hi All
My name is Jörg and i have a question wrt skeinforge settings. I have set skeinforge to a lasercutter profile and a layer thickness of 0,1 mm to become a svg file that only contains the object without toolpath. But it dosent works like i hoped. So please can you help me if you know how the settings have to be.
Thanks
Cu Jörg
Re: Skeinforge settings for a svg without toolpath
January 08, 2010 07:23PM
If you click the skeinforge button, skeinforge will output a gcode file. To get an svg file from the cutting profile, bring up the chop pane, then on the chop pane click the chop button.
Cheers,
Enrique
PS.
The best place for skeinforge questions is the "Skeinforge announcement and troubleshooting blog", at:
[fabmetheus.blogspot.com]
January 09, 2010 03:03PM
Thank you enique
But i have a question. When i do what you say then i become a svg with blue outlines and green infill so belong the blue outline to the part or is only the green infill the part.
Thank you
Cu Jörg
open | download - frame-vertex_6off_chop.svg (341.4 KB)
January 12, 2010 01:36AM
The cutting path is the blue outline.
January 13, 2010 12:58PM
Hi Enique
Thank you vey much this is what i wanted to know.
Cu jöerg
