Independent Z move May 09, 2010 08:22PM |
Re: Independent Z move May 10, 2010 08:24AM |
Re: Independent Z move May 10, 2010 08:55AM |
Re: Independent Z move May 10, 2010 09:28AM |
Admin Registered: 16 years ago Posts: 13,891 |
Re: Independent Z move May 14, 2010 08:58AM |
M105 ;need filler code for homing.gcode to get isolated Z movement
Re: Independent Z move May 17, 2010 07:04PM |
Re: Independent Z move May 29, 2010 08:54PM |
Re: Independent Z move July 07, 2010 08:53PM |
Re: Independent Z move August 10, 2010 10:37PM |
Re: Independent Z move August 21, 2010 10:24PM |
Re: Independent Z move August 22, 2010 05:06AM |
Even though my z raise command has the correct feed rate, I have to 'declare' it right before the command or it just make a quick vrrpt noise and doesn't raise.
RepRap does subtle things with feedrates.
Generation 7 Electronics | Teacup Firmware | RepRap DIY |
Re: Independent Z move August 23, 2010 12:16AM |
Re: Independent Z move January 30, 2011 12:41PM |
Re: Independent Z move January 30, 2011 05:51PM |
Re: Independent Z move January 30, 2011 07:13PM |
Re: Independent Z move January 31, 2011 03:07AM |
Re: Independent Z move February 01, 2011 12:00PM |
Re: Independent Z move February 01, 2011 12:10PM |
Chad C
Anyone have a Microsoft Word macro that will insert the G1 F30 command right before any line where the Z value has changed?
Re: Independent Z move February 01, 2011 12:23PM |
Re: Independent Z move February 01, 2011 01:14PM |
##---------------------------------------------------------------------------- ## Filename: AddG1F30.awk ## Author: Robert H. Morrison ## Date: 1 Feb 2011 ## ##-[ D e s c r i p t i o n ]-------------------------------------------------- ## ## Written for "Chad C" in forums.reprap.org. ## Add LAYER comments so LAYER M/N is displayed in the RepRap Host software. ## Add G1 F30.0 before each change in the layer height. ##---------------------------------------------------------------------------- FNR == 1 { ++file_num; Z = 0; layer = 0 } #; found_first = 0 } /^G1 X[0-9.]+ Y[0-9.]+ Z[0-9.]+ F[0-9.]+[ \t]*$/ { for (i = 2; i <= 5; i++) { Axis[substr($i,1,1)] = substr($i,2) } if (Axis["Z"] != Z) { Z = Axis["Z"] if (file_num == 2) { ++layer printf(";#!LAYER: %d/%d\n", layer, layers-1) printf("G1 F30\n") } else { ++layers } } } { if (file_num == 2) print }
AWK -f AddG1F30.awk "%1" "%1" > "Fixed_%1"
AddG1F30 MyFile.gcode
Re: Independent Z move February 03, 2011 07:15PM |
Re: Independent Z move February 03, 2011 07:37PM |
Re: Independent Z move February 04, 2011 11:47PM |
Re: Independent Z move February 06, 2011 01:54PM |
Re: Independent Z move February 11, 2011 05:22PM |
Re: Independent Z move June 03, 2011 11:08PM |
Re: Independent Z move June 17, 2011 06:51AM |
Re: Independent Z move June 17, 2011 07:08AM |
Re: Independent Z move June 24, 2011 02:31PM |
Re: Independent Z move June 26, 2011 10:28AM |
