Hi, for everyone want a "SendTo" conversion:
* Hit
windows key+"
R" (windows Run)
* write "
SENDTO" (or "
shellendTo" for vista/7) in run window.
* sendto window now shows some files like mail, my documents....
* create new .cmd file for your skeinforge command. rigth click over a blank place and press new->cmd
* edit cmd just created.
this is sample cmd:
@echo off
cls
echo Converting %1 to GCODE
cd "C:\Documents and Settings\daniel\Escritorio\dist"
skeinforge.exe %1
Must change cd line for your skeinforge location. I have a skeinforge exe distribution. if use python mas change line "
skeinforge.exe" for "
start python skeyforge.py %1"
save CMD file.
Modify the file for use a icon attached at this topic.
close sendto window.
Now, over an .STL file, can use rigth mouse click for fast and easy conversion your stl file to gcode.
Hope help.
Mendel Prusa with Gen7 v1.2 PCB , Wade's extruder 0.7mm. Custom Heated bed.
"BIG" Mendel Pusa with modified Gen7 V1.3 PCB , Wade's extruder 0.5mm with modified hotend (about 500x600x450mm printable area) <--- under construction
Plastics: Black PLA, Soft PLA, White ABS
Software: Skeinforge 4 for STL to GCODE, RepRap Host for print GCODE. Blender for STL designs.
