I was setting my PWOT (Perimeter Width Over Thickness) setting (Carve Tab) last night. I observed some odd behaviour (I think)
I printed a 20mm square cube with 0 solid layers and 0 infill, to give me a nice single walled cube. I printed it and measured the wall thickness. I did this for several different PWOT settings the idea being that I'd get 'the right one' and know that was the correct setting.
I was using a layer thickness of 0.4
- PWOT setting = 1.0, measured thickness 0.53. Therefore measured PWOT = 0.53/0.4 =1.325
- PWOT setting = 1.2, measured thickness 0.6. Therefore measured PWOT = 0.6/0.4 = 1.5
- PWOT setting = 2.0, measured thickness 0.93. Therefore measured PWOT = 0.93/0.53 = 2.325
So, it seems whatever I set the PWOT to in skeinforge, my actual (measured) PWOT is greater (approx 0.3 on that limited data).
Is this odd?
Am I doing something wrong?
An effect of this is that solid layers (100% infill) are always wrong (I set my Infill WOT the same as my Perimeter WOT).
My solution (such that it is) was to modify the Filament Packing Density (Dimension tab) to 1.25 (1.5/1.2=1.25 for a PWOT setting of 1.2). This did the trick - the wall thickness was approx 0.44 giving a measured PWOT of 1.2). However, that feels like a nasty solution. I'm not sure if there are other effects I'm not aware of.
I just wondered what peoples thoughts are
Thanks
Pete
