changing nozzle size
Posted by Flyer2
November 06, 2012 05:56PM
Hi
i want to change my nozzle size from .5 to .35 with 3mm filament. Do i need to make a change somewhere in skeinforge to reflect this?
Re: changing nozzle size
November 07, 2012 04:44AM
If you use Skeinforge 40 or more and volumetric calibration (Dimension plugin) you don't have anything to tell to Skeinforge – just to make the calibration tests again…
François
November 07, 2012 06:31AM
Well, just get sure to lower your layers height accordingly.
With a .35 nozzle layers of .25 are probably the maximum thickness usable to properly lay the extruded plastic.
November 07, 2012 07:08AM
Ok- thanks for the input.
