Feed Rate problem [SOLVED]
Posted by Gersen
July 25, 2014 09:27AM
I'm using Skeinforge for a few days and I noticed an issue with the feed rate/speed: when I set the feed rate this is correct only in the solid layers, in the others the program set a speed lower then the feed rate. This speed is different with the same gcode generates on different computers(11mm/s, 5mm/s). This speed increase with higher level of infill solidity, reaching the feed rate with 1.0 of infill solidity.
This is a problem because the print time with 20% infill or 100% infill is the same.
Any idea?
Edited 1 time(s). Last edit at 07/26/2014 07:20AM by Gersen.
Re: Feed Rate problem [SOLVED]
July 26, 2014 07:21AM
The problem was, the "minimum layer time" too high.
