Perimeter loops ends
Posted by B4Me
August 14, 2012 03:00AM
Hi
Im new to Skeinforge, and therefor dont know what to do at this point... I've got some pret nice 20x20x5mm test cubes by now..
BUT at every loop end on the outer shell (perimeter) I get an ugly missing piece of line... what I mean is when it goes from the outer to the second perimeter, I leaves a small hole in the wall... I tried to increase Jitter to 100, but now they just are all over the object.
Any setting to make them go away ?
EDIT:
Sorry but didnt take any pictures of it, will post some later today, after work
Edited 1 time(s). Last edit at 08/14/2012 03:01AM by B4Me.
Re: Perimeter loops ends
August 14, 2012 05:27AM
Possible helps :
In the "Fill" module, choose "Thread sequence" as "Loops > Perimeter > Infill" (will make the inside perimeters printed before the outer one, not sure if will help).
Disable the "Clip" module if it's on. (I feel that might be the source of your problem).
August 14, 2012 05:58AM
I'll test it later to day.. I'm off in 4 hours smiling smiley
was printing that stupid cube all night changing a LOT of stuff to fix this tongue sticking out smiley
isnt the idea with Clip, to remove the blobs at each loop start ?
August 14, 2012 06:17AM
Yes but with nowadays machines speeds it's becoming useless and a possible source for problem like yours if not properly set up.
I have it disabled, never felt a need for it - retraction and "fast" print speed is reducing blobing enough for me.
August 14, 2012 06:40AM
At which speed do you run your printer ?
I have a Printrbot, and atm it running 25mm/s *0.3
on perimeters
August 14, 2012 07:56AM
My outer perimeters are printed at 20 to 60 mm/s depending on the object.
But my non printing moves are always 150mm/s - I could probably push it more but didn't take the time to test it. The machine is a Prism Mendel.
I Believe those non printing moves speed is one key that avoid blobs on the surface (I also use a lil retraction).
IMO, you should try to disable clip, and see if that improves your hole-in-the-wall problem.
If blobs appears instead, you could still enable Clip back and try to set it up properly by trial and error.
August 14, 2012 04:41PM
Here's a picture of my "issue":
August 16, 2012 06:23AM
So, being curious, have you managed to improve your prints regarding the wall-holes issue ?
Also from looking at your parts pictures, I believe you have whether a Z and/or E steps_per_mm issue, or you are trying to print using layers heights larger than what your nozzle can properly do.
What hints me in this idea is the way we can clearly see a round section of the deposited filament in your walls, if deposited properly if should be far less noticeable (nearly flat wall).
August 16, 2012 07:17AM
Havnt had the time to fix it yet sad smiley work work work...
First: you are aware that the picture is showing the side of the cubes ? so the lines on the side on this picture is my Raft leftovers
But my nozzle is 0.5
and its puting out 0.58 in diameter when testing it at slooooooooooow speeds in free air.
my width over height is 1.67 (should be this number AFAIK)
But I have ajusted my Filament Packing Density variable under Dimension
It should be 0.8 for ABS, but I found that 1.15 gives me the best infill..at 0.8, its putting out way to much filament
August 16, 2012 07:41AM
Yup, noticed the bottom has raft, I was talking about the sides, that are shown as top on the picture.
With this WOH of 1.6666, you are probably printing layers of 0,3 mm, aren't you ?
And, mmm, IMO empirically playing with the Filament packing density is not very precise.
I'd rather measure the actual length of your most often used plastic type (PLA or ABS) when doing a "extrude 100mm" command at an average extruding speed, with your hotend properly heated etc to mimic the actual printing behaviour as much as possible - and ajust the firmware e_steps value accordingly.
Then switch to your less often used plastic type, redo the measuring and remember the ratio of difference (if any) for use as the FPD when needed.
August 16, 2012 01:18PM
Remeasured my E steps.. no change so far..
But of what I can see, the problem is at every loop START.. it looks like mt extruder is putting a "blob" at the start of the loop.
And that's the thing I can see sticking out on the above picture :-/
Edited 1 time(s). Last edit at 08/17/2012 03:51AM by B4Me.
August 17, 2012 02:50AM
Could you share your skeinforge profile here ?
August 17, 2012 03:51AM
When I get home I will smiling smiley approx 5 hours till..
August 17, 2012 10:52AM
I played a little with the ooze-bane and retraction, and got the following result, still having blobs some times but far less, and clip is probably the reason for the holes.
attach profile as zip.
What can be seen is that most of the blob is gone now.. but was Oozebane the right setting for this problem ?
open | download - 0.35 ABS.zip (19.4 KB)
August 17, 2012 10:29PM
Oozebane is useless for stepper motor extruders, it was meant for DC geared motor extruders that couldn't retract because they were too slow.
Help improve the RepRap wiki!
Just click "Edit" in the top-right corner of the page and start typing.
Anyone can edit the wiki!
August 19, 2012 07:58AM
Your Clip Over Perimeter Width value is quite high.
The default is 0.2, you use 1.0.
Lowering it would probably remove those gaps - just make sure it's not too low or bulge could happen instead.
August 19, 2012 03:05PM
> high.
> happen instead.
I know it's pretty high, but I did that in an attempt to remove the blob I have at every loop start.. It didn't f
Make any difference to the blob
November 09, 2012 03:24PM
Try set faster feed rate on Z moving.
